YOHKOH Posted July 8, 2008 Share Posted July 8, 2008 Reflection map override in the vray environment is tiling in reflections instead of stretching. Any ideas?? Link to comment Share on other sites More sharing options...
jameson101 Posted July 11, 2008 Share Posted July 11, 2008 Instance the map that you have in the Reflection map override onto a material in the material editor. Then play around with the mapping of the material in the material editor. If its not working on the texture option the try it on the Environ option, play around with the settings until something works. Hope this helps let me know, if this is not the issue then post an render Link to comment Share on other sites More sharing options...
YOHKOH Posted July 12, 2008 Author Share Posted July 12, 2008 That worked Thanks a lot Link to comment Share on other sites More sharing options...
