Road line problem
jhop
Hi all, I'm having a problem where my road lines off in the distance blur away. I'm using a blend layer with a road texture, a white line texture and a black and white image for the road lines that bring the two together. how do I get it to be sharp all the way back? I'm using max with MR.
Cheers
You can also change your filtering in your bitmap parameters. Setting it to "none" will not blur the image at all. Technique-wise, we use lofted or sweep splines to create lane lines. Might try that as an alternative.
