vux777 Posted July 12, 2008 Share Posted July 12, 2008 Is it possible to have 3ds max 9 and 3ds max 2008 on same computer, both with Vray as rendering engine? When I try to install vray for max 2008 (I alredy have max 9 with vray), I get the message that I should uninstal previose version of vray. Thanx btw. this is a great forum, and this is my first post... keep up with the good work guys Link to comment Share on other sites More sharing options...
WAcky Posted July 13, 2008 Share Posted July 13, 2008 This is a question that should probably be asked of the folk at chaosgroup. Try the forums there. Link to comment Share on other sites More sharing options...
vux777 Posted July 13, 2008 Author Share Posted July 13, 2008 ok, thanx WAcky Link to comment Share on other sites More sharing options...
e_cbautista Posted July 13, 2008 Share Posted July 13, 2008 Is it possible to have 3ds max 9 and 3ds max 2008 on same computer, both with Vray as rendering engine? When I try to install vray for max 2008 (I alredy have max 9 with vray), I get the message that I should uninstal previose version of vray. yes it is possible to have 2 versions of max (i have installed max9 and max2008). heres what i did: 1. install max9, install vray. 2. rename vray folder from Program Files, or copy it into a new location in the harddrive 3. install max2008, install vray, (it will report that an old version is installed already but wont see it because you renamed the folder) 4. restore the folder name for max9's vray 5. .. and you're good to go. Link to comment Share on other sites More sharing options...
vux777 Posted July 13, 2008 Author Share Posted July 13, 2008 I did it, easy way. There is a Vray for max 2008 1,50,17sp1 (basically it's the same vray for max 9 ) that has different dll names, so no conflicts or errors during insatllation. Link to comment Share on other sites More sharing options...
