Sawyer Posted January 21, 2004 Share Posted January 21, 2004 This is sort of a lame duck question as it has nothing to do with rendering stuff. Client wants the cad drawn site plan to look hand drawn. No coloring or "graphics" just a cad site plan looking hand drawn. The idea is that while the plan is finished the developer is afraid that showing the neighbors a finished plan will get them upset. If we shown them something a bit "softer" they may not get as mad. I won't really defend that logic. I tried Sketchup and while I like it is seems a bit of information is being lost in the conversion. Any good ideas out there? Link to comment Share on other sites More sharing options...
jucaro Posted January 21, 2004 Share Posted January 21, 2004 You can try and use distortion and diffusion filters. Link to comment Share on other sites More sharing options...
Sawyer Posted January 21, 2004 Author Share Posted January 21, 2004 Jucaro- have you been able to get a good effect in photoshop for just lines? I can get a look I like for an NPR like image but only with images not line drawings. If you have been able to get a good look please let me know how you did or at least a hint. Regardless thanks for the reply. Link to comment Share on other sites More sharing options...
Chad Warner Posted January 21, 2004 Share Posted January 21, 2004 The other option would be to use squiggle..I'm not sure of the website, or your budget, but it's whole purpose is to make CAD drawings appear hand drawn. -Chad Link to comment Share on other sites More sharing options...
STRAT Posted January 21, 2004 Share Posted January 21, 2004 ask Ernest, he's an NPR diva Link to comment Share on other sites More sharing options...
Tim Nelson Posted January 21, 2004 Share Posted January 21, 2004 If you have acad 2004, there should be a feature that will turn your linework into the sketchlook. I tried it once before in ADT 2004, but hopefully its also in the regular version Link to comment Share on other sites More sharing options...
STRAT Posted January 21, 2004 Share Posted January 21, 2004 Originally posted by Timmatron: If you have acad 2004, there should be a feature that will turn your linework into the sketchlook. I tried it once before in ADT 2004, but hopefully its also in the regular version can you tell me what function that is? only i use ADT 4 and havent yet come across that. may be usefull Link to comment Share on other sites More sharing options...
Sawyer Posted January 21, 2004 Author Share Posted January 21, 2004 Chad Warner - Thank you for the tip that is what I was looking for. Timmatron - I do have 2004 and I have not run across anything like that yet. Please hook me up if you have any info. Link to comment Share on other sites More sharing options...
jucaro Posted January 21, 2004 Share Posted January 21, 2004 Hi sawyer, is this the kind of effect you are looking for? I can also achieve a 'sign pen on table napkin drawing' look if you want. :ebiggrin: NPR PLAN (235 KB 1024X1024 image) Link to comment Share on other sites More sharing options...
Tim Nelson Posted January 21, 2004 Share Posted January 21, 2004 Hope this helps you to find it. Again, not sure if Autocad 2004 has it but ADT 2004 definitely does. Its under the content browser. Here's a screenshot of the menu and also a quick example of a sketch from a floorplan I did. It's got a few basic options that you can play with. good luck Sawyer! Tim Link to comment Share on other sites More sharing options...
Robin Posted January 21, 2004 Share Posted January 21, 2004 Try ArchiCAD with ArchiSketchy plug-in Link to comment Share on other sites More sharing options...
jucaro Posted January 21, 2004 Share Posted January 21, 2004 For those who dont have ADT, here's the "napkin drawing" look by using 2 overlayed glass distortion filters in photoshop. Link to comment Share on other sites More sharing options...
Ernest Burden III Posted March 17, 2004 Share Posted March 17, 2004 From within most CAD programs, you can use a wiggley linestyle--there is one called 'squiggle' I think, available for AutoCAD. And if ACAD offers it, just use 'line overshoot'. In Datacad, this feature will display lines extended by an amount you set, say, 6", on a site plan you would want more like 18". This look exports perfectly to a vector PDF file, or can be rasterized into Photoshop. Datacad does NOT have a randomizing tag for the overshhot, so I used to use several values for different line colors. You can see what that looks like in : my antique tutorial on hybrid rendering the images are not very big, now that I look at it again. But the point is, I would suggest doing hand-drawn lines in your CAD program. You can also do it by filtering in PS, of course, which is what I do now. Link to comment Share on other sites More sharing options...
