NPR Site Plan Lines
Sawyer
This is sort of a lame duck question as it has nothing to do with rendering stuff.
Client wants the cad drawn site plan to look hand drawn. No coloring or "graphics" just a cad site plan looking hand drawn. The idea is that while the plan is finished the developer is afraid that showing the neighbors a finished plan will get them upset. If we shown them something a bit "softer" they may not get as mad. I won't really defend that logic.
I tried Sketchup and while I like it is seems a bit of information is being lost in the conversion.
Any good ideas out there?
Jucaro- have you been able to get a good effect in photoshop for just lines? I can get a look I like for an NPR like image but only with images not line drawings.
If you have been able to get a good look please let me know how you did or at least a hint.
Regardless thanks for the reply.
Originally posted by Timmatron:
If you have acad 2004, there should be a feature that will turn your linework into the sketchlook. I tried it once before in ADT 2004, but hopefully its also in the regular version
can you tell me what function that is? only i use ADT 4 and havent yet come across that. may be usefull :)
Hope this helps you to find it. Again, not sure if Autocad 2004 has it but ADT 2004 definitely does. Its under the content browser. Here's a screenshot of the menu and also a quick example of a sketch from a floorplan I did. It's got a few basic options that you can play with.
good luck Sawyer!
Tim
  • 1 month later...
From within most CAD programs, you can use a wiggley linestyle--there is one called 'squiggle' I think, available for AutoCAD. And if ACAD offers it, just use 'line overshoot'. In Datacad, this feature will display lines extended by an amount you set, say, 6", on a site plan you would want more like 18". This look exports perfectly to a vector PDF file, or can be rasterized into Photoshop. Datacad does NOT have a randomizing tag for the overshhot, so I used to use several values for different line colors.
You can see what that looks like in :
my antique tutorial on hybrid rendering
the images are not very big, now that I look at it again.
But the point is, I would suggest doing hand-drawn lines in your CAD program. You can also do it by filtering in PS, of course, which is what I do now.
