Multipple Slices
Matt Sugden
Hi, does anyone know of a quick way of creating multiple slices across a poly or object at regular intervals in Max?
I need to make some uniform grooves in a shape.
The object is irregular shape so I can not just tessellate it. And I need to do a lot of slices so I don't want to do it manually if possible.
Cheers.
Guest nazcaLine
why not a shape merge? draw the section you want, make an array, then attach them all together and pick your geometry you want to slice, shape merge your line shape and that's it.
unless i misunderstood your problem
cheers
Eduardo
