Brute Guy Posted July 16, 2008 Share Posted July 16, 2008 Hi, I'm in the process of texturing some tyres. I'll refer to the attached pictures bump_a.jpg and bump_b.jpg: I'd like to texture the tyres as shown in 'bump_b.jpg' however I would like the material shown in 'bump_a.jpg' as my material for the tyre. Problem is the texture in 'bump_a.jpg' (really fine fractal bump) is already taking up my bump slot. How can I use the material in 'bump_a.jpg' as my main tyre material but then apply the bump shown in 'bump_b.jpg'? Any thoughts? Cheers Marc Link to comment Share on other sites More sharing options...
vux777 Posted July 16, 2008 Share Posted July 16, 2008 try blend material (the most left icon-blend-choose 2 materials to mix-set the mix amount around 50 and that's it Link to comment Share on other sites More sharing options...
Peter M. Gruhn Posted July 17, 2008 Share Posted July 17, 2008 Either a Mix Map or an RGB Multiply map might do the job. Drop one into a new slot. They each have two slots in them for sub maps. Put the noise in one slot and the tread in the other slot. (Set the Mix Map to 50% mix for starters.) Go back to the good material. Replace it's noise bump map with the mix or mult map. The two options have different behaviours. You may need to tweak the submaps to make them work better together. I'm only on Max 9, I think the new version has an updated Composite map with Photoshop type blend modes. One of those may be good too. - gruhn Link to comment Share on other sites More sharing options...
Brute Guy Posted July 17, 2008 Author Share Posted July 17, 2008 Hi Many thanks to both of you for your replies, i've not dabbled with mix maps much, but i'll be sure to try. Ta Marc Link to comment Share on other sites More sharing options...
