craigball Posted July 17, 2008 Share Posted July 17, 2008 (edited) Hi Can any one help me sort out the nose I am getting around the side of the bed and on the bed. I have posted some screen shots, Thanks Edited July 18, 2008 by craigball Link to comment Share on other sites More sharing options...
kippu Posted July 17, 2008 Share Posted July 17, 2008 craigball said: Hi Comments are appreciative, can any one help me sort out the nose I am getting around the side of the bed and on the bed. I have posted some screen shots, Thanks must be a tiny nose because i cannot see it Link to comment Share on other sites More sharing options...
craigball Posted July 17, 2008 Author Share Posted July 17, 2008 kippu said: must be a tiny nose because i cannot see it It is there, did you have a look at the screen shot? if so do the settings look right to you? as i am new to vray. thanks Link to comment Share on other sites More sharing options...
jameson101 Posted July 21, 2008 Share Posted July 21, 2008 Try some of these changes and see if it helps. Put primary bounces multiplier down to 2. I have never used it above 2 before I usualy just leave it on 1. Under your Irradiance map tab change Hsph subdiv to 30 and also inter samples to 30. Turn detail enhancement off. Detail enhancement slows render down. Under Light cache tab change sample size to 0,01. Also why do you have 8 passes, Do you have a dual quad core? Your light cache must be taking ages, change it to 2 or maybe 4. Under global switches Tab switch Default Lights off. Under image sampler Tab switch Antialiasing filter to Catmull-Rom. Its a nice edge enhancement filter. Under Colour mapping tab change it to either Linear multiply or intesity exponential, play around with those two. I have never use gamma correction before and havent seen anyone else use it. Also under your sun setting put shadow bias to 0.1. If none of these help let me know, hope that you get it sorted out. Link to comment Share on other sites More sharing options...
