murtazasimari Posted July 17, 2008 Share Posted July 17, 2008 hii guys i install 3d max9 32 bit & i install properly but its showing one error i don't know this is regarding hardware or software problem please just give me your advice... Link to comment Share on other sites More sharing options...
WAcky Posted July 17, 2008 Share Posted July 17, 2008 you need to post more information if you want help. Is this occuring when you try a certain function or is it happening after xx minutes of max being open? Link to comment Share on other sites More sharing options...
murtazasimari Posted July 17, 2008 Author Share Posted July 17, 2008 its happen while rendering the image i put some furniture blocks from autocad & i import the file to 3D max than i applied materials when i click on render than its showing error. Link to comment Share on other sites More sharing options...
WAcky Posted July 17, 2008 Share Posted July 17, 2008 Ive never tried to import a block but i'ver heard bad things about them... Try exploding the block before you import it. I have no idea if this will work but it might be worth a try. Link to comment Share on other sites More sharing options...
murtazasimari Posted July 17, 2008 Author Share Posted July 17, 2008 thanks James.. but i tried also its also not working anyway i install again the application & try again same thing... Link to comment Share on other sites More sharing options...
kippu Posted July 17, 2008 Share Posted July 17, 2008 how about file linking ? Link to comment Share on other sites More sharing options...
murtazasimari Posted July 17, 2008 Author Share Posted July 17, 2008 i just import the file from autocad to 3d max...thats it Link to comment Share on other sites More sharing options...
Mike. Posted July 19, 2008 Share Posted July 19, 2008 (edited) you are very far from the zero point. i don't know if this has a relation whith your problem, but you should do this thing properly. center your autocad drawing or export a wblock whith base point near your object. being too far from zero can cause many geometry problems.... you should first clean your autocad drawing, purge it, control it, center it around zero or move your ucs, AND THEN export it. Edited July 19, 2008 by Mike. Link to comment Share on other sites More sharing options...
SandmanNinja Posted July 19, 2008 Share Posted July 19, 2008 And from an earlier post: To centre the origin in AutoCAD (preparing to bring it into 3DS): in autocad, use the 'move' command (M) and when asked to select objects, type 'all' (make sure all layers are on and not frozen/locked) hit 'enter' and when asked for a base point, select a point in the center of your model (or where ever you want the origin to be). once you have that, then type in 0,0,0 to move it - this is the origin point in autocad where the intersection of the X/Y/Z axis meet. Link to comment Share on other sites More sharing options...
murtazasimari Posted July 20, 2008 Author Share Posted July 20, 2008 thanks dear.. but i installed 3d max 8 again coz i think my 3d max 9 is corrupted..& its working fine but some time i need to consider all above points... thanks buddy... Link to comment Share on other sites More sharing options...
bsm3d Posted July 20, 2008 Share Posted July 20, 2008 I see you have Vray open, have this error when you try to render in Scanline or Mental ray mode ? Link to comment Share on other sites More sharing options...
