3d studio max and Autocad Architectural Desktop materials not preserved on reload
d7man2000
Can someone help me with reloading scenes in 3d studio max when importing objects from ADT( Architectural Desktop/Autocad)?
Materials are not preserved. Everytime when I reload materials are not recognized on objects that did not change.
thanks.
Check use scene materials on reload
to elaborate a bit unless they've fixed this (which i doubt) you need to make sure you have a preset that is set to hold the materials on reload when you do the initial attachment. If you don't set this from the start it doesn't work later on as you are experiencing.
Check the advanced tab for the two material option boxes.
You are only supposed to check "scene materials on reload" as the guys said. I'm not to sure what scene material definitions are. Maybe someone could explain this one once and for all as I have seen this a couple of times with no explanation what it does. You can save a preset when you get it right and use that all the time it is in the basic tab.
