Guest nazcaLine Posted July 23, 2008 Share Posted July 23, 2008 i have a box. i want to apply a vray disp modifier to only one of the faces. i used a mesh select modifier, applied the vray disp mod and a uvw map (planar) but it applies the disp map to the whole box . what can i do? i don't want to detach that face, but maybe is it the only option??? please help...! Eduardo Link to comment Share on other sites More sharing options...
blowback Posted July 23, 2008 Share Posted July 23, 2008 the only way I got it to work was to detach the face .... so then what is with the (tex chan) in the modify panel Link to comment Share on other sites More sharing options...
Guest nazcaLine Posted July 23, 2008 Share Posted July 23, 2008 i think that refers only to the map...or is it the poly ID?? let's see Link to comment Share on other sites More sharing options...
blowback Posted July 23, 2008 Share Posted July 23, 2008 so ????? just wondering? Link to comment Share on other sites More sharing options...
Guest nazcaLine Posted July 24, 2008 Share Posted July 24, 2008 I had to detach it. Link to comment Share on other sites More sharing options...
bened Posted July 25, 2008 Share Posted July 25, 2008 Try using a multi-subobject material with two identical materials but only one with the displacement map activated. Be sure your map is black around the edges or the face will detach!! Link to comment Share on other sites More sharing options...
salvador Posted June 16, 2011 Share Posted June 16, 2011 I've been trying to do this myself too. No luck. There is a texture channel in the vray disp modifier but still it applies the modfier to the whole mesh. Link to comment Share on other sites More sharing options...
