Dave Buckley Posted July 24, 2008 Share Posted July 24, 2008 basically how do i know that i am getting the full potential from Max on a dell precision m90 64bit XP pro 4gb RAM, what do i need to do in order to configure it properly so that i am getting maximum output from Max Link to comment Share on other sites More sharing options...
SandmanNinja Posted July 24, 2008 Share Posted July 24, 2008 Hi Dave, I have a quad core with 8 gigs of ram running XP64, and use Max 2008 Design (64-bit). The operating system does all the work for you. You won't have to put a command line switch on the shortcut or anything. It's a proper, stable, smooth, lean operating system. And - everyone asks this - it will only use the ram if it needs to use the ram. Link to comment Share on other sites More sharing options...
Dave Buckley Posted July 24, 2008 Author Share Posted July 24, 2008 ok joel so i installed xp 64 and i got max 64 etc, but when i look at my computer>properties, it is only showing 3.5gb RAM???? y is this??? i want 4gb Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted July 24, 2008 Share Posted July 24, 2008 I would say add another 4gb for a total of 8. Also, depending on your video spec's, and the size of your models, tweaking Adaptive Degradation might be necessary. Getting the full potential out of max lies in your working methods as much as it does setting up the software properly itself. Unless you are using the new features in the Scene Explorer dialog, I would also revert that back to the old version. The new version is currently slower. Link to comment Share on other sites More sharing options...
alrawli Posted July 24, 2008 Share Posted July 24, 2008 Also worth considdering if you have an Nvidia graphics card then the Maxtreme driver does make a bit of a difference. Link to comment Share on other sites More sharing options...
Dave Buckley Posted July 24, 2008 Author Share Posted July 24, 2008 i have nvidia quadro fx 3500 so how do i know if i'm using this 'maxtreme' driver Link to comment Share on other sites More sharing options...
Matt McDonald Posted July 24, 2008 Share Posted July 24, 2008 The M90 is a laptop and won't take 8Gb of RAM. The reason that your system does not display 4Gb of RAM is due to memory mapping. A system typically moves the memory allocated for the PCI devices into unused memory space. Because the motherboard in your laptop only supports 4Gb of RAM and you have 4Gb of RAM there is no room to remap the memory to. Therefore Windows reports 3.something GB of RAM. If (for example) you had motherboard that maxed out at 8Gb of RAM and you filled it up, Windows would only report 7.something Gb of RAM due to the space occupied by your PCI devices. Link to comment Share on other sites More sharing options...
SandmanNinja Posted July 25, 2008 Share Posted July 25, 2008 Yeah - what Matt said. I don't really consider Laptops as 'true' PCs. Hardward is too specialised. Link to comment Share on other sites More sharing options...
Ky Lane Posted July 25, 2008 Share Posted July 25, 2008 They're designed to be portable, not powerful Link to comment Share on other sites More sharing options...
Matt McDonald Posted July 25, 2008 Share Posted July 25, 2008 I dunno... I have an M90 and its pretty trick! Link to comment Share on other sites More sharing options...
