karolisbilz@yahoo.com Posted July 24, 2008 Share Posted July 24, 2008 hey there can some1 tell wtf is this weirdness in my model....i know similar to this happenes when there are 2 same objects in the same place but it's not this case.....it looks weird and i dont know what to do with this......this is shape lofted by a path ....and as i didn't render it untill suirten point i don't know if this anomaly was from the begining.....but i think it was cause i didn't to to damn thing much just conveted it to editible poly.... Link to comment Share on other sites More sharing options...
Ky Lane Posted July 24, 2008 Share Posted July 24, 2008 Checked your UVW coordinates? Link to comment Share on other sites More sharing options...
gfa2 Posted July 24, 2008 Share Posted July 24, 2008 it does look like double faces. maybe your lofted shape had a double spline in it and it actually made double faces without you knowing? try setting the secondary rays bias to 0.01 and see if that clears it up. Link to comment Share on other sites More sharing options...
Peter M. Gruhn Posted July 25, 2008 Share Posted July 25, 2008 Weird Thing 2 may have a vertex weld failure at that inside corner. This might be consistent with some of what other people are saying. Go in and test move one vertex, make sure you don't have two. Do all the faces you'd think would move along with it do so or do some stay in place? Link to comment Share on other sites More sharing options...
Peter M. Gruhn Posted July 25, 2008 Share Posted July 25, 2008 Oh yeah, on on WT2 I wonder about those very black up facing polys. Are they supposed to be that black? Do they exist? Are they facing the wrong way? Link to comment Share on other sites More sharing options...
karolisbilz@yahoo.com Posted July 25, 2008 Author Share Posted July 25, 2008 no that's the same anomaly as in 1st picture..... Link to comment Share on other sites More sharing options...
jsf Posted July 25, 2008 Share Posted July 25, 2008 In my experience Max doesn't turn corners well when using loft or sweep. Make single straight run loft segments then miter the pieces at the corners. This method may seem time consuming but so is spending all day looking for a workaround without success. Link to comment Share on other sites More sharing options...
