anupam das Posted July 25, 2008 Share Posted July 25, 2008 Hi , i am newcomer in maya modeling. But i can't convert a high detailed model into a low poly model. is there any way to convert high poly model into low poly in maya. plz post reply as early as possible Link to comment Share on other sites More sharing options...
shaneis Posted July 25, 2008 Share Posted July 25, 2008 Manually collapse your edge-rings or merge edge-loops. There is a poly "Reduce" tool, but it rarely works. Collapse edge-rings: 1. Select edge ring (Select>Select Edge Ring Tool), double-click edge to select the ring 2. Hold Shift, right-click and select Merge/Collapse Edges > Collapse Edge. Next time, save your low-poly mesh before you Smooth and also learn how to use Smooth Proxies. Link to comment Share on other sites More sharing options...
