malevy Posted July 27, 2008 Share Posted July 27, 2008 I have been trying to create onyx trees in 3ds for the last week and i am not getting very far. I have been following Brian's video tutorial and i understand most of it except the part where he is adding maps to the material editor for he leaves. Can someone explain this in a few simple steps so i can get past this point already. I use the eye dropper and select the plant to get the colors into the material editor and after that point i am lost.. Please help!!!! Link to comment Share on other sites More sharing options...
Tommy Burns Posted July 28, 2008 Share Posted July 28, 2008 When you do this what you are getting is a sub-object material which has a lot of different materials in here. What you have to is find out which one of these is the leaf material it is usually named appropriately and just add your maps to this material. there is also something you have to adjust in the treestorm parameters to allow it view maps. It shows you this in the video. Hope this helps Link to comment Share on other sites More sharing options...
malevy Posted July 28, 2008 Author Share Posted July 28, 2008 Thank you for your help.. I finally did figure it out last night. So what happens when you get a tree with needles instead of leaves how do you apply an image to the needles or do you just use the vertex colors instead of images When you do this what you are getting is a sub-object material which has a lot of different materials in here. What you have to is find out which one of these is the leaf material it is usually named appropriately and just add your maps to this material. there is also something you have to adjust in the treestorm parameters to allow it view maps. It shows you this in the video. Hope this helps Link to comment Share on other sites More sharing options...
Tommy Burns Posted July 29, 2008 Share Posted July 29, 2008 No problem I'm not to sure of the needles way i only ever had to use leaves maybe someone else will know. I imagine it's the same way only the mapping may be different. Link to comment Share on other sites More sharing options...
