pradipta Posted July 27, 2008 Share Posted July 27, 2008 I am working on an exterior animation, where i am currently building the night setup. I find Photometric light is giving better lighting effects but is Photometric light (with IES) takes longer to render than Omni while having at least 3000 of them in a scene? I will appreciate any help, thank you Link to comment Share on other sites More sharing options...
kaz031 Posted July 28, 2008 Share Posted July 28, 2008 I'm not too sure of all the technical tricks but maybe just use the photometric lights in particular areas where you really need them and then omni for the rest. Link to comment Share on other sites More sharing options...
pradipta Posted July 28, 2008 Author Share Posted July 28, 2008 Thanks Karyn, I also thought the same thing. I will use photometric with IES for some closeups and omni for the rest, this will save a lot of time. Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted July 28, 2008 Share Posted July 28, 2008 Why would you use omnis instead of spherical VRayLights? Link to comment Share on other sites More sharing options...
pradipta Posted July 29, 2008 Author Share Posted July 29, 2008 While experimenting I saw Omni are rendering faster than vray spherical light, so, I was asking if Omni's are really faster for larger scene? ad photometric with IES took longer also in most cases. Ricardo, please share your ideas on this thank you Link to comment Share on other sites More sharing options...
kippu Posted July 29, 2008 Share Posted July 29, 2008 i would have thought vray spherical lights would render faster , but then maybe you are not using shadows with the omnis in which case omnis would be faster Link to comment Share on other sites More sharing options...
Nic H Posted July 29, 2008 Share Posted July 29, 2008 Iv always found omnis quicker and more controllable than vray sphericals, espcially useful with falloff/attenuation controls - more flexible. Link to comment Share on other sites More sharing options...
