nanderson2008 Posted July 28, 2008 Share Posted July 28, 2008 The bottom and sides of the pool that are under the water are textured with a blue tiles texture. Problem is they are not visible through the water in render. The water is a plane, settings for the material are shown. Any advice how to fix this? Cheers. Link to comment Share on other sites More sharing options...
RobNJ73 Posted July 28, 2008 Share Posted July 28, 2008 Make sure "Affect Shadows" and "Affect Alpha" are checked in the refraction parameters. Link to comment Share on other sites More sharing options...
kiittea Posted July 28, 2008 Share Posted July 28, 2008 I wonder why you're using diffuse map .....i am attaching u r image with few suggestions ... hope this helps you Link to comment Share on other sites More sharing options...
nanderson2008 Posted July 28, 2008 Author Share Posted July 28, 2008 I've removed the diff and reflect maps, and changed it to a typical water material but the water still dosn't seem transparent. I've rotated a copy of the water plane to test that you can see through it, the material seems ok. I am trying to get the water looking similar to the attached image (from another post) but cant figure out what is wrong... Link to comment Share on other sites More sharing options...
RobNJ73 Posted July 28, 2008 Share Posted July 28, 2008 As Kittea stated, use the fog color swatch and the fog multiplier to control the color of the water. Link to comment Share on other sites More sharing options...
Trevor Tizard Posted July 29, 2008 Share Posted July 29, 2008 Also you need to select "Affect shadows" Link to comment Share on other sites More sharing options...
Ky Lane Posted July 29, 2008 Share Posted July 29, 2008 And use a solid, not a plane. Link to comment Share on other sites More sharing options...
karolisbilz@yahoo.com Posted July 29, 2008 Share Posted July 29, 2008 i know this wasn't the topic here, u asked about the water and stuff......but u should REALY work on ur house it is way out of proportion and messes up the whole scene....for instance my hands would be choped off at work if i disegned a house with such proportions ... Link to comment Share on other sites More sharing options...
shaneis Posted July 29, 2008 Share Posted July 29, 2008 karolisbilz@yahoo.com said: i know this wasn't the topic here... You're right, it wasn't, but don't let that stop you from chiming-in with something useless. Nick, what are your Raytrace settings? Make sure the reflect/ refract rays are set high enough (use 6 each just to be sure). Maybe check the plane's normals are pointing the right way. Considering the rotated plane is also blocking your environment and returning black, I tend to think that it may be an env issue. Just double check that your env image and env settings are as they should be. S. Link to comment Share on other sites More sharing options...
Nic H Posted July 29, 2008 Share Posted July 29, 2008 use a solid volume, it will look better. Link to comment Share on other sites More sharing options...
karolisbilz@yahoo.com Posted July 31, 2008 Share Posted July 31, 2008 hey shane ......f**k off how useless is tha, ha? Link to comment Share on other sites More sharing options...
STRAT Posted July 31, 2008 Share Posted July 31, 2008 lets take it easy eh fellers? Link to comment Share on other sites More sharing options...
kiittea Posted July 31, 2008 Share Posted July 31, 2008 woooo calm down... guys .... Link to comment Share on other sites More sharing options...
Nic H Posted July 31, 2008 Share Posted July 31, 2008 internet threads - cereal business Link to comment Share on other sites More sharing options...
nanderson2008 Posted July 31, 2008 Author Share Posted July 31, 2008 At the side of the pool ive put a copy of the pool water object and it seems ok, but in the pool it is still dark and not see through. Ive only covered half of the pool with the water object to test. Any more ideas what's wrong and how to get it right? Cheers. Link to comment Share on other sites More sharing options...
Ky Lane Posted July 31, 2008 Share Posted July 31, 2008 Make sure the box in the pool doesn't intersect the sides of the pool, or no internal reflections/refractions will happen. Zoom right in, and make sure its very close, but not overlapping. Link to comment Share on other sites More sharing options...
Horhe Posted July 31, 2008 Share Posted July 31, 2008 Easy guys, no need to take it so roughly.... Link to comment Share on other sites More sharing options...
