Ky Lane Posted July 28, 2008 Share Posted July 28, 2008 Well, yes it is! I have a rather complex internal apartment scene which I rendered out a couple months ago now when I was still using 32bit Vista. Now, same machine, exact same specs etc running on 64bit rendered the exact same scene out (I didnt change anything) about 25% quicker. Go figure! Link to comment Share on other sites More sharing options...
manta Posted July 28, 2008 Share Posted July 28, 2008 well if you have 4 gigs of ram in that machine, it probably used it in the 64bit, and didn't use it in the 32bit, and was using the hard drive instead which is much slower than Ram... Link to comment Share on other sites More sharing options...
Antisthenes Posted July 28, 2008 Share Posted July 28, 2008 windows 2008 x64 20% faster Link to comment Share on other sites More sharing options...
Ky Lane Posted July 28, 2008 Author Share Posted July 28, 2008 well if you have 4 gigs of ram in that machine, it probably used it in the 64bit, and didn't use it in the 32bit, and was using the hard drive instead which is much slower than Ram... Of course, and the extra theoretical gig of ram helps too, although 25% is a pretty big difference if you were looking at rendering out a huge animation or something.. Link to comment Share on other sites More sharing options...
SandmanNinja Posted July 29, 2008 Share Posted July 29, 2008 THAT is EXACTLY the kind of benchmarking I was looking for. Thanks Ky... Link to comment Share on other sites More sharing options...
