Replacing point helper with and object
alrawli
We have a file with positions of bollards and these positions are marked in Max as Point Helpers and we would like to replace these en masse with a bollard model. Ive got a couple of replace scripts which work with replaceing objects for objects but they dont seem to work with replacing a helper for an object. Does anyone know of any work arounds or scripts out-there?
Cheers
Al.
Hmm, couldn't find it online, so i dont remember what the original authors name was (i *think* it was swami), but this works.
fn objsToProcessAsArray objsToProcess =
if classOf objsToProcess==array then
	if objsToProcess.count!=0 then return objsToProcess
	else return undefined
if objsToProcess==undefined then return undefined
if classOf objsToProcess==ObjectSet or classOf objsToProcess==PathName then
	objsToProcess=objsToProcess as array
	if objsToProcess.count!=0 then return objsToProcess		-- At least one object in array.
	else return undefined						-- NO objects in array!
-- Check for single object passed (and convert to array if true).
local validSuperClasses=#("camera","GeometryClass","helper","light","shape","SpacewarpObject")
local sClassObjsToProcess=(superClassOf objsToProcess) as string
for sClass in validSuperClasses where
		local execStr="superClassOf objsToProcess=="
		execStr += (sClass as string)
		execute execStr
do
	return #(objsToProcess)
if classOf objsToProcess==SelectionSet then
	return (for obj in objsToProcess collect obj)
undefined	-- If none of the above checks are true, then 'objsToProcess' was invalid
			-- (e.g. an integer, float, etc.).
fn instanceEm objsToProcess:(getCurrentSelection()) =
objsToProcess=objsToProcessAsArray objsToProcess
if objsToProcess!=undefined AND objsToProcess.count>1 then
	local objMaster, obj
	objMaster=objsToProcess[1]
	for i=2 to objsToProcess.count do
		obj=objsToProcess[i]
		instanceReplace obj objMaster
	select objMaster
format "test"
instanceEm()
