carlos_7 Posted September 23, 2003 Share Posted September 23, 2003 Hi guys, I have a problem with some shadows. I am using a couple of spot lights with shadow maps. I have a hall with a door and the light behind the door is leaking through the wall. Any idea how to solve this? Thank you very much, PD: I would post a picture but I don't have a URL so far Link to comment Share on other sites More sharing options...
Jeff Mottle Posted September 23, 2003 Share Posted September 23, 2003 Use our upload utility. You can find the link to the left of the message posting box Link to comment Share on other sites More sharing options...
carlos_7 Posted September 23, 2003 Author Share Posted September 23, 2003 Thank you Jeff, Here is the image. ttp://www.cgarchitect.com/forum/filepush.asp?file=shadow-map-_1.jpg Link to comment Share on other sites More sharing options...
carlos_7 Posted September 23, 2003 Author Share Posted September 23, 2003 OOpss, my mistake. I copy the URL worng. Here is . This one should work. http://www.cgarchitect.com/forum/filepush.asp?file=shadow-map-_1.jpg Sorry Link to comment Share on other sites More sharing options...
STRAT Posted September 24, 2003 Share Posted September 24, 2003 classic light leakage. 1) turn the light's bias down to 0 2) you mustn't have faces running through faces - each wall and junction in the wall MUST match up perfectly, all verts must weld up. Link to comment Share on other sites More sharing options...
carlos_7 Posted September 24, 2003 Author Share Posted September 24, 2003 Thank you STRAT for your help I set the Bias to 0. And the problem of the faces is doubled checked to make sure is ok. When I did the walls I made them from a plane extruding the faces so there shouldn't be any vertex unwelded. I hope you have any other suggestion. Take care Link to comment Share on other sites More sharing options...
STRAT Posted September 24, 2003 Share Posted September 24, 2003 can you post a simple wire frame piccy of the walls mesh please? Link to comment Share on other sites More sharing options...
carlos_7 Posted September 25, 2003 Author Share Posted September 25, 2003 Thank you again for your help Strat. This is an image of the room. I extruded the faces from a box and cut away the faces for the door, then fix the open faces of the sides, so it should be any unwelded vertex where I am having the problem. I hope the image can help. http://www.cgarchitect.com/forum/filepush.asp?file=extruded-faces2.jpg Thanks Link to comment Share on other sites More sharing options...
STRAT Posted September 25, 2003 Share Posted September 25, 2003 it looks like the wall with the doorway cut out if it actually goes into the main wall on the left there. on the right it sails all the way through it. make sure the wall edges meet up exactly together and actually weld together. there should be no walls going through walls or anything like that. Link to comment Share on other sites More sharing options...
carlos_7 Posted September 25, 2003 Author Share Posted September 25, 2003 How can I check that the edges are welded together? Link to comment Share on other sites More sharing options...
STRAT Posted September 25, 2003 Share Posted September 25, 2003 if your working in max, and you've modelled the walls and edges EXACTLY matching up to each other, they'll automatically weld together if all the walls are part of the same object when you bring them into max. even if those 2 walls are separate objects, they dont have to be welded. they only have to match edges exactly. no sailing through or over laping or intersecting or just placing faces against/through faces. email me a dxf of that bit of the mesh and i'll check it out if you want. Link to comment Share on other sites More sharing options...
STRAT Posted September 26, 2003 Share Posted September 26, 2003 this ok? i just took a look at your mesh you e-mailed me. the structure of the mesh was ok, as you pointed out (very poly heavey tho, too many steps in the extrution process). Your problem was with your lighting settup. fix it like this - 1) select and modify SPOT03 2) in SHADOW MAP PARAMS change the BIAS from your original 3.0 down to 0.0 change your MAP SIZE from 256 up to 500 change your SAMPLE RANGE from 5 up to 20 3) then in the SHADOW PARAMETERS roll out change the DENS. from 1 to 4. your lighting rig needs work anyway, but this will sort out your problem. Link to comment Share on other sites More sharing options...
carlos_7 Posted September 26, 2003 Author Share Posted September 26, 2003 Thank you Stephen, you have been very helpful. I appreciate your help a lot. Link to comment Share on other sites More sharing options...
carlos_7 Posted September 26, 2003 Author Share Posted September 26, 2003 Do you have any advise for the linghting rig? Thanks Link to comment Share on other sites More sharing options...
