VRAY Sun and Sky
Dave Buckley
When using the Vray sun it automatically puts in a VRay sky environment map. My question is does this map then give me my environment lighting????
Or do i still need to turn on GI Skylight in the vray rollout???
From what i gather they are both doing the same thing, in other words i could use one or the other???
By putting a Vray Sky in the environment slot of your dropdown, you are able to control both the Sky and the environment individually. You can tone down the VraySky and bump up the environment lighting in your dropdown menu or vise-versa.
i quite like using the physical cam regardless of the scene, as i like the exposure controls on it.
but with regards to lighting, i guess it depends whichever solution does what i need it to do in the quickest time and renders the fastest :)
but i do quite like the way the sun/sky changes colours etc when you move it around in 3d space
is there a direct control for setting time/date/location in vray or has that not been introduced yet??
btw thanks for the help so far guys
just to clarify when using daylight system to put sun in location, i select vray sun BUT when it comes to selecting skylight i assume i turn off the daylight system skylight as my vray sky environment is doing that right??
Yep, you got it.
Cool guys this is much appreciated
slight problem
i cleared the vray sky from the rendering>environment slot
and instead i instanced it to the GI environment skylight and turned that on, however when i did that my environment was black
any ideas
Because there is nothing there any more. You won't see the sky in your render if you remove it from the Rendering>Environment slot..........that's why it goes there by default.
i have another thread going about magic hour renders
i reckon its quite difficult to achieve with the vray sun and sky, because what i am after is that time in the day when the sky is dark blue but their is still a setting sun glow on everything.
as soon as turn my sun to about 6pm, the lighting is ok for my exposure physical cam settings but the sky is mega orange
