shamsam1 Posted August 1, 2008 Share Posted August 1, 2008 i have 2 lisp program i want to combine it and make it once ,please guide me how to proceed fisrt lisp program to change layer color second lisp program to add materiel to layer insted of list i want a function whee i am mention either layer name and color or layer name and material.. '''change layer color (defun c:layd(/ Lst curLay fLst laySet) (setq Lst (list '("layer1" 10) '("layer2" 20) ); end list ); end setq (vl-load-com) (foreach lay Lst (if (not (vl-catch-all-error-p (setq curLay(vl-catch-all-apply 'vla-Item (list(vla-get-Layers (vla-get-ActiveDocument (vlax-get-acad-object)))(car lay)))))) (progn (vla-put-Color curLay(cadr lay)) (setq fLst(list(cons 8(vla-get-Name curLay)))) (if (setq laySet(ssget "_X" fLst)) (progn (foreach itm (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr(ssnamex laySet)))) (vla-put-Color itm acByLayer) ); end foreach ); end if ); end progn ); end progn ); end if ); end foreach (princ) ); end of c:layd '''-------------- '''''''-----attach materil (defun c:pumat(/ Lst sSet mLst cMat sCnt lCnt mCnt eCnt) (vl-load-com) (setq Lst (list ' ("0" "Global") ' ("layer1" "BLUE GLASS") ' ("3_250580E" "BLUE GOOSE") ); end list ); end setq (vl-load-com) (if(setq sSet(ssget "_X" '((0 . "*SOLID")))) (progn (setq sCnt 0 lCnt 0) (vlax-for mat (vla-get-Materials (vla-get-ActiveDocument (vlax-get-acad-object))) (setq mLst(cons(vla-get-Name mat)mLst)) ); end vlax-for (foreach itm (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr(ssnamex sSet)))) (if(setq cMat (cadr (assoc (setq cLay(vla-get-Layer itm))Lst))) (if(member cMat mLst) (if(vl-catch-all-error-p (vl-catch-all-apply 'vla-put-Material (list itm cMat))) (setq lCnt(1+ lCnt)) (setq sCnt(1+ sCnt)) ); end if (if(not(member cMat mCnt)) (setq mCnt(cons cMat mCnt)) ); end if ); end if (if(not(member cLay eCnt)) (setq eCnt(cons cLay eCnt)) ); end if );end if ); end foreach (if(or(/= 0 lCnt)(/= 0(length mCnt))(/= 0(length eCnt))) (progn (princ "\n========================= ERROR LIST =========================\n") (if(/= 0(length mCnt)) (progn (princ "\nFollowing materials missed in drawing: \n") (foreach mat mCnt (princ(strcat "\n " mat)) ); end foreach (princ "\n") ); end progn ); end if (if(/= 0(length eCnt)) (progn (princ "\nSome solid layers missed in list: \n") (foreach lay eCnt (princ(strcat "\n " lay)) ); end foreach (princ "\n") ); end progn ); end if (if(/= 0 lCnt) (princ(strcat "\n" (itoa lCnt) " were on locked layer!\n")) ); end if (princ "\n========================== END LIST ==========================\n") (textscr) ); end progn ); end if (princ(strcat "\n (itoa sCnt) " of " (itoa(sslength sSet)) " solids >>>")) ); end progn (princ "\n No Solids Found ") ); end if (princ) ); end of c:pumat ''''-------- Link to comment Share on other sites More sharing options...
