Inxa Posted August 1, 2008 Share Posted August 1, 2008 Hello, I am working on this interior. Using 3ds max and vray I am issue is even with high parameters the renders gets noise in it. If you look closely on the left side wall, ceiling you will notice the noise. All vray light have high subdivisions. around 12 each. Metal material also has high subdivs. My lc - 1000 and irmap is high / custom with high parameters. Can any one help me. Thanks in advance. Link to comment Share on other sites More sharing options...
Hao La Posted August 1, 2008 Share Posted August 1, 2008 Does your Vray light put out side the window? make sure they are not blocked by the wall. And also, what is your DMC Sampler setting? Link to comment Share on other sites More sharing options...
Inxa Posted August 1, 2008 Author Share Posted August 1, 2008 Hello, Ah great to get a reply from you. Alright. Here we go. I have placed all the windows outside. No blocks for sure. Also, the dmc in the image sampler is default. I tried working with high values but then the render become tooo slow plus the difference isn't very much. irmap settings - high / custom with high settings. lc - 1500 - 2000 sampler size .01 vray dmc sampler - adaptive amount : .85, noise threshold : 0.005, min samples - 10, global sub divs : 2. I am still working on to get rid of the noise. What do you suggest. Link to comment Share on other sites More sharing options...
Kopeykin Posted August 1, 2008 Share Posted August 1, 2008 I think this because of antialiasing. Are you using adaptive subdivision? Play with thresholds. Or try decrease Adaptive amount in QMC Sampler and AA - Fixed with 4 subdivs. Link to comment Share on other sites More sharing options...
Inxa Posted August 2, 2008 Author Share Posted August 2, 2008 Hey, With high image sampler parameters for adaptive dmc I have managed to get rid of the noise. Thanks for replying hao la and kopeykin. Link to comment Share on other sites More sharing options...
xulinlianggj Posted August 2, 2008 Share Posted August 2, 2008 I think vraylight's subdivs 20 or 30 or 50 Link to comment Share on other sites More sharing options...
Inxa Posted August 4, 2008 Author Share Posted August 4, 2008 (edited) I am re-rendering I will post up the finals soon. Edited August 4, 2008 by Inxa Link to comment Share on other sites More sharing options...
Hao La Posted August 4, 2008 Share Posted August 4, 2008 I think vraylight's subdivs 20 or 30 or 50 those numbers are way to high. In my experience, Vray's light subdivs at 15 will give you a good image without noise from the lights Link to comment Share on other sites More sharing options...
monkeyman905 Posted August 14, 2008 Share Posted August 14, 2008 Hi, what was the solution for the noise? Link to comment Share on other sites More sharing options...
