passing value from autocadcommand line to lisp
shamsam1
Passing parameters between functions is easy
(defun bar (p1 p2)
(princ(+ p1 p2))
(defun C:FOO ()
(bar 2 3)
(princ)
command: foo
5
Doing the same with a command function... that seems to be harder.
Got an answer. Don't like it.
(defun C:FOO(p1 p2)
(princ(+ p1 p2))
(princ)
Command: (c:foo 7 3)
10
this is what i like to try
pumat("layer1" "material 1"),("layer2" "material 2"),("layer3" "material 3")
i wan to pass values from command line to my lisp program
in my lisp program already list is there for materil and layer ..insted of predefining that i want to pass value from command line...
=========sample program======
(defun c:pumat(/ Lst sSet mLst cMat sCnt lCnt mCnt eCnt)
(vl-load-com)
(setq Lst (list
' ("0" "Global")
' ("layer1" "material 1")
' ("layer1" "material 2")
); end list
); end setq
(vl-load-com)
(if(setq sSet(ssget "_X" '((0 . "*SOLID"))))
(progn
(setq sCnt 0 lCnt 0)
(vlax-for mat (vla-get-Materials
(vla-get-ActiveDocument
(vlax-get-acad-object)))
(setq mLst(cons(vla-get-Name mat)mLst))
); end vlax-for
(foreach itm
(mapcar 'vlax-ename->vla-object
(vl-remove-if 'listp
(mapcar 'cadr(ssnamex sSet))))
(if(setq cMat
(cadr
(assoc
(setq cLay(vla-get-Layer itm))Lst)))
(if(member cMat mLst)
(if(vl-catch-all-error-p
(vl-catch-all-apply 'vla-put-Material
(list itm cMat)))
(setq lCnt(1+ lCnt))
(setq sCnt(1+ sCnt))
); end if
(if(not(member cMat mCnt))
(setq mCnt(cons cMat mCnt))
); end if
); end if
(if(not(member cLay eCnt))
(setq eCnt(cons cLay eCnt))
); end if
);end if
); end foreach
(if(or(/= 0 lCnt)(/= 0(length mCnt))(/= 0(length eCnt)))
(progn
(princ "\n========================= ERROR LIST =========================\n")
(if(/= 0(length mCnt))
(progn
(princ "\nFollowing materials missed in drawing: \n")
(foreach mat mCnt
(princ(strcat "\n " mat))
); end foreach
(princ "\n")
); end progn
); end if
(if(/= 0(length eCnt))
(progn
(princ "\nSome solid layers missed in list: \n")
(foreach lay eCnt
(princ(strcat "\n " lay))
); end foreach
(princ "\n")
); end progn
); end if
(if(/= 0 lCnt)
(princ(strcat "\n" (itoa lCnt) " were on locked layer!\n"))
); end if
(princ "\n========================== END LIST ==========================\n")
(textscr)
); end progn
); end if
(princ(strcat "\n
(itoa sCnt) " of "
(itoa(sslength sSet)) " solids >>>"))
); end progn
(princ "\n No Solids Found ")
); end if
(princ)
); end of c:pumat
