SpeedTree 4 and Vray DR ???
karol
Hello eveyone
i have this problem which is on rendering the maps.
i created trees on speedtree then imported them into 3ds max 9
i use DR with 3 machines everyone of them has INTEL quad CORE 2.66ghz.
the problem is when i render the scene the maps seem like they are turned off ,except the main computer im using is not and the maps appears only on its buckets while the other computers buckets dont show the maps as i said above :eek:.
other thing is i put all the maps in the maps folder in 3ds max root folder.
unfortunatlly they didn't appear i tried to convert the trees maps from TGA format to JPEG to see if they'll work
but didn't work
if anyone had the same problem i really need to know and i'll be real grateful for the help
note:any idea how to create shared folder that i can put all the map's folder in it and all the machines on my network can access without losing the time and switching to every computer using the Remote Desktop Connection and copy the files manually
appreciate the help!!!:eek::D
thank you:o
