Need some displacement help!
Miggity
Can somebody help me with figuring out how to render my displacement in a seperate pass. When I try to render I keep getting "Unhandled exception: Sampling Displacement maps." When I turn off displacement in Vray it works fine but I don't know how to render the displacement in a separate pass.
Im not sure if these is a memory issue but if it is the 3gb switch fixed all my problems....
normally if you have a large fiels uising Displadement it take up quite a bit of memory and it used to crash on me....If you are using 2d mapping try reducing the resolution.
The surfaces are flat planes of grass, mulch and concrete, regular site plan stuff. i am using 2d displacement and the areas really aren't that large. Could it have anything to do with the geometry?
I am using a simple grass with the VRay displacement modifier. I have a general question though, do you need to put the VRay displacement modifier on every piece of geometry that you want displaced? If so what is the point of the displacement map in the material? Just some stuff I have been thinking about.
So saying I can't get the displacement to render how do you set up a separate pass for the displacement?
  • 3 years later...
