harrowboy Posted August 4, 2008 Share Posted August 4, 2008 Hi, I've been playing with this mat but couldn't get it right. As you could probably see in the attached img, some of the glass panels along the handrails are acting as if they were mirrors. (but the same material worked fine for the roof and shopfront windows and they are transparent) It is just a standard glass material that I'm having.. Diffuse: black, fresnel reflections checked Reflect: gray almost white Refraction: white, affect shadow/alpha checked can anyone tell what's wrong? Thx. Link to comment Share on other sites More sharing options...
yepee9 Posted August 4, 2008 Share Posted August 4, 2008 set the reflections low . a black/dark grey color.or use fall off map on reflection.with color of black and grey. Link to comment Share on other sites More sharing options...
BrianKitts Posted August 4, 2008 Share Posted August 4, 2008 does all of your glass have a thickness? if the roof and shop windows have a proper thickness but the railing is just a single plane, then the single plane geometry will act as a mirror. A proper glass material needs the thickness to properly refract the light, if you only get a single refraction then you won't see any transparency in your object and you are left with just the reflection hence the mirror effect. Link to comment Share on other sites More sharing options...
harrowboy Posted August 5, 2008 Author Share Posted August 5, 2008 yes Brian, it was the problem with my modelling, the glass became transparent after I face extruded the geometry and applied shell. thanks. Link to comment Share on other sites More sharing options...
Ky Lane Posted August 5, 2008 Share Posted August 5, 2008 Are they set to fresnel? Link to comment Share on other sites More sharing options...
