navnow Posted August 4, 2008 Share Posted August 4, 2008 hi I'm working on an interior project. The modeling, lighting and material is done in max 8 using vray 1.5RC2. A sample render of this file took around 4 mins. ( Image attached). Just to test, i opened the same file in max2008 V-ray 1.5 (i.e. modeling, lighting and material is done in max 8), without making any changes, a sample render took around 1 hr in max2008 ( Image attached) and the output is a dark room. I'm attaching scene images, light, material and rendering settings... Please help me know what the problem is.... thank u. Link to comment Share on other sites More sharing options...
Scott Schroeder Posted August 6, 2008 Share Posted August 6, 2008 When you open an older vray scene in the latest build of Vray, a warning dialog should open stating that the settings have changed from the older builds of Vray. I think some of the changes are with the DMC settings which would defiantly lead to the longer render times. If this dialog appears, it will ask you if you want to update the settings. I would highly suggest doing so. Link to comment Share on other sites More sharing options...
navnow Posted August 6, 2008 Author Share Posted August 6, 2008 hi.. yes.. i updated the settings. and thanks for the reply Scott. Link to comment Share on other sites More sharing options...
