some important questions.tnx.
gius84
a big hallo to all users! I'm newbe on this forum.
i have the demo version of fry, for this i can't ask nothing on ufficial fry-forum. :(
i use max plug-in
At first i have some simple questions. :confused:
* i ask if is possible do a render without the caustics layers, how can put on or off this option??
* what is the difference between several types of antialias, and their influence on time render??
*about the environment, i can put only a background image without affect on the illumination and reflection of the scene environment??
*......aaand the difference between "importance sampling" and "environment only" ??
i have finish all...sorry but they are the only doubts that i have. :D
Hi Giuseppe and welcome. :)
No, you can't disable caustics, except by using Ghost glass, which doesn't produce caustics.
If you mean the Anti-Aliasing setting in Output Configuration, No AA is only good for quick previews and is pretty fast. Default AA is ideal for rendering images 1000x pixels or larger and uses far less ram than Maximum AA. Default and Maximum render in the same time, one just uses less ram. Use Maximum for small output.
The anti-aliassing filters in the Post tab are interactive and can be changed in real time either during rendering or once you've halted the render.
Yes, the Background slot is for showing an image in the background which does not affect illumination or reflections. It will also not show through dielectrics with any degree of refraction.
Right now, there is no difference. Importance sampling will be back soon.
thanks frances, you have been synthetic and clear.
also if i'm still surprise about "caustics layers"...
;) a last favor, i'm very curious to know settings "oellas_cloth_A" material...but i have only the demo version of fry...i can't use the "Materials Repository".... you can send me this material or the texture and setting...also because i want reproduce it on maxwell :D
.gius.
