andrewdavidyoung Posted August 6, 2008 Share Posted August 6, 2008 In they latest mental ray there is a subset of scene shader that can render the pixels of a specific material. I was wondering if anyone knows of one that will work for V-ray. I have a masking script one, which is great for editing in specific regions in post but i really want to make adjustments in the render without having to render the entire scene. Link to comment Share on other sites More sharing options...
Dave Buchhofer Posted August 6, 2008 Share Posted August 6, 2008 http://www.scriptspot.com/3ds-max/vray-matte-pass-on-selected is a little script to speed the process for a selection of objects.. basically select what you want to keep and everything else will be matte'd out if you want to do it for a material you use the VrayMtlWrapper http://www.spot3d.com/vray/help/150SP1/mtlWrapper_params.htm or else look into the Render Element for MultiMatteRenderElement to just save out alpha channels for the areas you wish to adjust while doing the main renders. Link to comment Share on other sites More sharing options...
andrewdavidyoung Posted August 6, 2008 Author Share Posted August 6, 2008 Thank you very much. You are a gentleman and a scholar. I appreciate the quick response. Link to comment Share on other sites More sharing options...
