Guest nazcaLine Posted August 6, 2008 Share Posted August 6, 2008 simple question: how can i make an adjustment layer affect only a particular layer? when i apply the adj layer it affects ALL layers beneath it. i want to apply it to just one layer. how can i do this? itried new group layer, or linkin layers, but nothing any ideas??? please.. Eduardo Link to comment Share on other sites More sharing options...
RobNJ73 Posted August 6, 2008 Share Posted August 6, 2008 When you apply the adjustment layer, in the pop-up window that comes up, there should be a check box marked "use previous layer to create clipping mask". Just make sure that box is checked. Link to comment Share on other sites More sharing options...
Guest nazcaLine Posted August 6, 2008 Share Posted August 6, 2008 errr...no, i don't see this option...i want to apply a Curves adjustment layer, for example, and i just get a simple curves dialog box...no option there...am i missing something?? Link to comment Share on other sites More sharing options...
frank1331 Posted August 6, 2008 Share Posted August 6, 2008 You need to Alt-click between the adjustment layer and the layer below it, so that it only effects that layer. Link to comment Share on other sites More sharing options...
BrianKitts Posted August 6, 2008 Share Posted August 6, 2008 place your adjustment layer directly on top of the layer you want it to only affect and press Ctrl + Alt + G and it will group it to apply only to the layer below it. Link to comment Share on other sites More sharing options...
Guest nazcaLine Posted August 6, 2008 Share Posted August 6, 2008 thank you very much guys, problem solved! frank: you were right, i just had to make the new adj layer from the menu. thanks guys... Link to comment Share on other sites More sharing options...
