kentmccoy Posted August 8, 2008 Share Posted August 8, 2008 how does one get a .png or .jpg, etc to .skp that when it is pasted into su it shows up in the relevent component library? apparently only skp or sketchup formats will show up in the component libraries?? Link to comment Share on other sites More sharing options...
creasia Posted August 8, 2008 Share Posted August 8, 2008 Import it with the "as image" option selected/explode it and make it a component. Link to comment Share on other sites More sharing options...
kentmccoy Posted August 8, 2008 Author Share Posted August 8, 2008 thanks--that worked but the tree image lays flat on the ground plane and i cant seem to rotate it up?? why is it stuck flat--bryce is standing at right angles to it--cant lift it up?? Link to comment Share on other sites More sharing options...
Burk Posted August 9, 2008 Share Posted August 9, 2008 Context menu and detach it ( I don't know the english word used in Sketchup ) Otherwise change the glue in the component edior. Link to comment Share on other sites More sharing options...
stevel Posted August 14, 2008 Share Posted August 14, 2008 When you import the image, click once to anchor it in place. Then you can rezise it by dragging the cursor up and down (the size will show up in the VCB), or enter a size you want in the VCB and hit "Enter". Then click again to select it, then right-click and select "explode". It will be placed in the "In Model" category (make sure you are in the correct category you're after--either components or materials). If you want to save the image in your library, click on the little arrow icon (I think it's an arrow) on the right, and choose "save as library", then make a new folder and it will be saved. Link to comment Share on other sites More sharing options...
