MesaPrs Posted August 9, 2008 Share Posted August 9, 2008 Hi everybody, I've seen plenty of posts about issues exporting a sketchup scene to 3dsMax, and there have been some great solutions, but I've run into another problem. When I export a model in 3ds format, "by material" and "single object", reorganize the grouping and weld everything back together, I always have a problem chamfering edges (as I don't think a plugin exists that will chamfer multiple edges together in SU...). Some edges will chamfer fine but there's always some that distort badly as if there's an extra edge in there oriented in the wrong direction. Welding with a tighter threshold and exporting from SU with the vertexes intact don't seem to work. Has anyone run into this or know how to get around it? Link to comment Share on other sites More sharing options...
Dave Buchhofer Posted August 10, 2008 Share Posted August 10, 2008 i have run into it, and unfortunately dont have a good solution.. if you're using Vray, take a look at using the VrayEdgesTex in the bump map.. to do chamfering at rendertime, i know theres a similar thing in metnal ray, but dont recall what it is. Link to comment Share on other sites More sharing options...
MesaPrs Posted August 11, 2008 Author Share Posted August 11, 2008 Nice! I'll just use VrayEdgesTex - that sounds a whole lot less time consuming than chamfering edges in the model. Thanks, that solves my problem! Link to comment Share on other sites More sharing options...
