extrude along path not at right location
chow choppe
Hi all
we are facing a problem in extruding object along path
its like a moulding around a square coloumn
so we made the cross section of the moulding and then drew the path around the column but when we use Extrude comand and then use path option then the resulting object is getting shifted a little and the object is also smaller in size in plan . i never faced any problem like this in AUTOCAD 2004 but in 2006 or 2007 i face this problem.
If we copy paste the cross section and path into a new file it works fine
What can be the error. its like as if Cg of the cross section is not aligning properly with the path and even if we place the crossection at the edge of the path maybe its extruding the section with some other point as reference. I can be wrong also. Please help
Thanks
