murtazasimari Posted August 10, 2008 Share Posted August 10, 2008 hii guys Is there any way in 3d max to remove unnecessary layer like in auto cad i use purge command & its remove all unnecessary layers from my drawing. so if its there in max also than please suggest me. Link to comment Share on other sites More sharing options...
SandmanNinja Posted August 10, 2008 Share Posted August 10, 2008 You can delete any empty layer that isn't selected as the default layer. Do you mean delete the layer and all of the objects on that layer? Link to comment Share on other sites More sharing options...
murtazasimari Posted August 10, 2008 Author Share Posted August 10, 2008 ya the layer which is empty & its not contain anything... Link to comment Share on other sites More sharing options...
SandmanNinja Posted August 10, 2008 Share Posted August 10, 2008 Hit the 'X' at the top of the layer manager window. It will ONLY be available if the layer is empty and not set to default. I usually go to the general/top layer & tick it as default/active layer and then select the layer to delete and hit the X. Link to comment Share on other sites More sharing options...
murtazasimari Posted August 10, 2008 Author Share Posted August 10, 2008 thanks man...appreciated Link to comment Share on other sites More sharing options...
Dave Buchhofer Posted August 10, 2008 Share Posted August 10, 2008 heres a little macro to delete all empty layers.. http://www.buchhofer.com/files/filehome/maxscripts/AearonSetup/Macros/Layers/remove_empty_layers.ms i use it all the time after cleaning up imported cad crap Link to comment Share on other sites More sharing options...
