sg3d Posted August 11, 2008 Share Posted August 11, 2008 Hey All, Need advice on best way to model the big top tent below. What way would you go about modeling this. Was thinking about using cloth modifer. Any suggestion? :confused:Thanks sg3d:confused: Link to comment Share on other sites More sharing options...
Claudio Branch Posted August 11, 2008 Share Posted August 11, 2008 I would use the Surface Toolset modifiers (Edit Spline, CrossSection, Surface) to model this. Here is a thread that might give you some ideas: http://www.cgarchitect.com/vb/29200-help-im-stuck-2.html Link to comment Share on other sites More sharing options...
Scott Schroeder Posted August 12, 2008 Share Posted August 12, 2008 If you are familiar with cloth, that could be one way of doing it. You can also just use a nicely detailed mesh and soft select the verts where the posts are. The soft select the edges down to meet the tent walls. A third way would be to get a start from the cloth sim, then refine the shape and details in edit poly or mesh mode. Link to comment Share on other sites More sharing options...
nelpiper Posted August 14, 2008 Share Posted August 14, 2008 I personally wouldn't use cloth as it's slow for this kind of model there'd be quite setup to do. I'd try having a nice and poly plan and work with soft selection. Hope it helps. Good luck. Link to comment Share on other sites More sharing options...
Matt McDonald Posted August 14, 2008 Share Posted August 14, 2008 I wish I had a project that required me to model a circus tent! Link to comment Share on other sites More sharing options...
sg3d Posted August 27, 2008 Author Share Posted August 27, 2008 Cheers all for the help. Got the big top done in the end. Here they are in a finished scene. Thanks again. [ATTACH]28677[/ATTACH] Link to comment Share on other sites More sharing options...
