Tim Nelson Posted August 11, 2008 Share Posted August 11, 2008 So I think I may have found a bug thats actually been bugging me for a long time. You know how when you merge in models that already have the same material in the scene, it will give you the message saying "a material name assigned to a merging object is a duplicate of a material in the scene. Do you want to:" Then you can either rename it, use the scene material, etc. But I've noticed that a lot of times, even when you say "use scene material" it will still bring in the merged material as a duplicate of whats already in the scene. So then you'll have two materials that are not even instanced to each other, and you have to manually assign the objects to one material if you want to clean it up. Really annoying right? WELL, I think I've figured out what is happening. When it asks you what you want to do, you can check the little box that says 'apply to all duplicate', and then hit the Use scene material. However, this does not work and thats what creates the problem. I've found that if you manually hit the 'use scene material' button for each duplicate material, it will properly use the material that is already in the scene! I just thought that is a little nuts, but I'm glad I found something that works finally. Has anybody else had the same problem? Link to comment Share on other sites More sharing options...
Gus_Rayvus Posted August 11, 2008 Share Posted August 11, 2008 Yeah, but I think that is the only solution, I have not found a better way to do it. Link to comment Share on other sites More sharing options...
Nic H Posted August 11, 2008 Share Posted August 11, 2008 yep, its bloody annoying - well before I worked out you have to manually click through it was. absolutely garbage typical 3dmax bug what max are you on? we are still on 9. Link to comment Share on other sites More sharing options...
Tim Nelson Posted August 11, 2008 Author Share Posted August 11, 2008 Max 2009, still there! I can't believe I didn't find out about it until now. I just thought it never worked, period. Link to comment Share on other sites More sharing options...
Lester_Masterson Posted August 11, 2008 Share Posted August 11, 2008 What I hate even more is when You have : MAT1 [object1, object2] MAT1 [object3] Why. oh why? Just slight differences in values (ie: one has 1 value higher in ambient, or something stupid) The only way I know how to remove is to select objects by material, then apply MAT1 to selected. Am I missing something? /found out about that damn "apply to all" bug back in Max 5.0 (thought it was something I was doing) Link to comment Share on other sites More sharing options...
