Motion Jerks in AE??
djoshi
I hv rendered animation in TGA sequence from max ( 25fps/PAL).
Now when I am importing it in AE & renders from there, it gives me little jerky motions.:confused:.
I hv tried premier it gives smooth motion,
But I want to do post in AE..What to do to get smooth motion in AE..??
Off hand i would guess that you can see the frame stepping. Do you see 25 little jerks ever second? It is a fairly common problem. I have recommended this to someone else, but haven't tries it myself, at least in a while. Try turning on Frame Blending in AE, or render out of Max with Motion Blur.
Thanx..
Oh ..I just got it..
When I was importing the TGA sequence.. It was showing 30fps in properties at project window. So I hv done interpret footage & changed the assumed time frame to 25fps ..& it worked...!! smooooth..
But really I dont know what has happened..Bcos my animation was in 25 fps/PAL from max..my project setting it AE is 25 fps/PAL then why it was showing 30fps in properties at project window...????:confused:
