Rendering Fire
Tommy L
I need to go beyond the usual fire flickering in a hearth for this one. Actually, by quite a long way...
I need to render a rolling mass of flame in the sky. Kind of like a sea of fire really and I need to be able to control the swirls.
Does anyone know of any specialist software for this kind of thing?
Im trying using a blizzard particle flow with motion blur at the moment. Im getting best results using scanline. My vehicle of choice is vray. I really need some modelling software that is designed for this though. Either a Max plugin or something external to do the fluid modelling.
Any advice much appreciated.
Tom.
Afterburn is good if you're going for explosion-type volumes of fireballs. But if it's more of a naked flame effect you're looking for, then FumeFX is the way you'd want to go.
Of course, it might all be easier to do in post... I don't think Afterburn or FumeFX will want to render with VRay. Could be wrong about this point, though.
^ Seconded.
FumeFX ( even though it's great ) is very calculation heavy and you really can't control it at "swirl level". IMO the best solution would be combination of max render and post processing. You could build a "base effect" in max and finetune (add elements) it to your liking in After Effects / Combustion / etc.
One thing you should check first would be
http://www.allanmckay.com/tutorials.html
And this one by him at 3dluvr.com
http://www.3dluvr.com/content/article/83/1
Edited by Tim_Tam
small correction
