Sketchrender Posted August 12, 2008 Share Posted August 12, 2008 I have photos taken with a 24 mm shift lense. This has been discussed, but i don't think with a Vray Cam. I have matched the best I can, the sensor is a full one ie Canon mark II. So does anybody know how to get an accurate result with a Vray Camera. Thank you Phil Link to comment Share on other sites More sharing options...
Tommy L Posted August 12, 2008 Share Posted August 12, 2008 Do you know the film gate of the camera? Thats the physical width of the sensor. Link to comment Share on other sites More sharing options...
Stephen Thomas Posted August 12, 2008 Share Posted August 12, 2008 Do you know the film gate of the camera? Thats the physical width of the sensor. It's a full-frame i.e. 35mm sensor, therefore your max camera should have the same focal length as the real-life lens. No focal length conversion required. A camera correction modifier will allow you to mimic the shift lens characteristics or if you are using a vray physical camera the vertical shift feature will do the job. Link to comment Share on other sites More sharing options...
Koper Posted August 13, 2008 Share Posted August 13, 2008 if all els fails, use the camera match utility of max to create a defualt camera and then use the lele vray tools to create a phys.vcam from that default cam. Link to comment Share on other sites More sharing options...
arkiedmund Posted August 18, 2008 Share Posted August 18, 2008 if all els fails, use the camera match utility of max to create a defualt camera and then use the lele vray tools to create a phys.vcam from that default cam. Nice suggestion sir. If you don't mind, can you share to us on how to go about doing max's camera match process, I've been trying to do this one with no success. A simple step by step guide will do, or better still, maybe you can share some link in the web that would point us in the right direction. Thank you so much... Link to comment Share on other sites More sharing options...
WAcky Posted August 18, 2008 Share Posted August 18, 2008 Theres a tutorial at evermotion.org that discusses the camera match feature. Link to comment Share on other sites More sharing options...
Koper Posted August 18, 2008 Share Posted August 18, 2008 and the max help document also explains it very good. just search for the 'Camera Match Utility' in the help document, not the max tutorials document. the this is the evermation one http://www.evermotion.org/tutorials/compositing/arch/ Link to comment Share on other sites More sharing options...
arkiedmund Posted August 19, 2008 Share Posted August 19, 2008 thanks a lot for the info, will try to check them out... Link to comment Share on other sites More sharing options...
