copain Posted August 16, 2008 Share Posted August 16, 2008 Hey guys hoping to get some help with this: Here is an image of scene I am rendering, as you can see it has a shadow of a tree( which is animated). Now my question is, what is the best way to render this? As there is no camera move it is just the shadow changing, is there a way of just rendering that region? thanks steve Link to comment Share on other sites More sharing options...
SandmanNinja Posted August 16, 2008 Share Posted August 16, 2008 With Max 2009 Design, you have Render Regions. Do 1 full render Switch to Render Region Marquee the area to render Press the Go Button Link to comment Share on other sites More sharing options...
copain Posted August 16, 2008 Author Share Posted August 16, 2008 hey Joel ,thanks but have not got the new version, still on max9 I am familiar with render region in maya was hoping max had it. But i did find a plugin called rrtool thanks steve Link to comment Share on other sites More sharing options...
STRAT Posted August 16, 2008 Share Posted August 16, 2008 use the letter box technique then Link to comment Share on other sites More sharing options...
copain Posted August 16, 2008 Author Share Posted August 16, 2008 hey stephen how does that work? Link to comment Share on other sites More sharing options...
STRAT Posted August 16, 2008 Share Posted August 16, 2008 you put a plain or face directly in front of the camera, and assign a pure black, non shadow/gi emitting, seen only by camera material to it. Then, punch out a hole where the action takes place. then hit render. Link to comment Share on other sites More sharing options...
copain Posted August 16, 2008 Author Share Posted August 16, 2008 hey thanks stephen. ll try it out now Link to comment Share on other sites More sharing options...
SandmanNinja Posted August 16, 2008 Share Posted August 16, 2008 Hey Steve, Which trees are you using to get the 'leaves moving in the wind'? I want to do an animation like that as well. I think it's a cool effect. Also, are the trees moving with Reactor, or are you keyframing the animation or how? Thanks! Link to comment Share on other sites More sharing options...
copain Posted August 16, 2008 Author Share Posted August 16, 2008 hey Joel I used onyxtree, There is a setting to create a wind effect. In my case,because you do not even see the tree, I just have a plane with an image sequence on it. Link to comment Share on other sites More sharing options...
