More imperfect terrain work ;) - need help aligning terrain to curve
Stan Zaslavsky
hi,
i've got a slightly falling slope on the site and have the elevation showing the curve.
is there a quick and easy way to align the flat plane to a curve?
see image enclosed
as i wrote the message - i realised i can use loft to get the original curve shape to become a plane :)
is there any easier way though than this way with an existing flat plane?
Edited by StanZ
Another way would be to use the sweep modifier, then covert it over to an editable poly if you need to adjust it......... sweeps are fantastic and well worth exploring if you dont already use them i use them for loads of different things facades, windowframes, door surrounds drainpipes etc the list goes on!
sounds great - this is what i ended up doing - splines then lofted to a path.
then there was lots of extruding and removing it from the main terrain - see image enclosed.
unfortunately the view we picked for the final render showed virtually none of the terrain outside the main development :( so there's a lesson not to do terrain if its not going to be in the final shot
all the best and thanks for all your input :D
