Final gather maps / net render
milfora
Hi,
This may sound like a dumb question, but I am wondering if it is possible to generate a final gather map across a render farm? My last project was a long roadway, on which the camera and the vehicles moved - which meant I had to generate fg at every frame.
Following the advice of the forum, I generated the FG map on one computer in the render farm - and it took approx 2 days of solid processing just to generate the *.fgm file (at 1/2 resolution, 1/64-1/64 samples, draft settings etc)
Is is possible to generate the FG as individual files across a network, and splice them together afterwards? (similar to normal network rendering)
Surely there has to be a quicker way...
Thanks in advance
AM
yes it is possible, but not recomended.
Due to the "Random" nature of the final gather samples each machine will calculate a sligtly different solution, thus when they are all sticked together ther could/would be flickering.
try it and see if it will work for you
jhv
