DR Help!! - only the first node of list is rendering!
seergjej
Hello, I am having some peculiar issues with vray direct rendering. All nodes have vrayspawner started (tried as a service and not but without results) and are resolved in the direct rendering rollout but only the first one in the list will join the workstation for DR.
I have 3 nodes and if I remove the first server from the rollout, then the one that was second before (the new first one in list) is used. Of course, the third never started, as well.
In the log there is no trace of any call to or registration from the inactive servers.
Only one server is used for rendering.
I don'tknow if I was clear enough, I am browsing so many forums but still haven't found an answer to this behavior.
Could it have to do with vrayspawner.ini? I don't have it and vrspawner uses default settings.
Any help is greatly appreciated!!
P.S. scene renders with no artifacts, network works!
I am using the following:
3DSMax Design 2009 SP1
VRay 1.5 SP2
PROBLEM SOLVED
Thanx anyway and greetings to everybody!!
Edited by seergjej
problem solved
