DRobertson_23 Posted August 21, 2008 Share Posted August 21, 2008 I am working on dell m1530 XPS and I am running 3DS Max Design 2009. When I start max up the buttons across the top show up as blocks with no pictures on them. Anyone have any idea how to fix this? Link to comment Share on other sites More sharing options...
SandmanNinja Posted August 21, 2008 Share Posted August 21, 2008 Try this (from my notes): weird problems with the interface?? Blow away (or rename) 3dsmax.ini C:\Documents and Settings\[uSERNAME]\Local Settings\Application Data\Autodesk\3dsmax\9 - 32bit\enu Link to comment Share on other sites More sharing options...
alrawli Posted August 21, 2008 Share Posted August 21, 2008 Could also try reloading the UI. Link to comment Share on other sites More sharing options...
DRobertson_23 Posted August 21, 2008 Author Share Posted August 21, 2008 Thanks for the help guys! Reloading the UI to it's default state fixed the problem. Link to comment Share on other sites More sharing options...
trino Posted August 21, 2008 Share Posted August 21, 2008 Yes, reloading the UI works also in Max 2008, but it is a shame that you have to loose all your custome toolbars, at least i still don´t know how to keep them Link to comment Share on other sites More sharing options...
