gamma correction in renderfarms : really urgent
kippu
Hi guys
I am sending out this job to a renderfarm but i worked the renders in linear workflow method with a gamma of 1.8 but it totally slipped my mind that it will not be possible for the farm to change their gamma....so is there anyother way other than i rework my lighting ?
yes it is off site ...theres no way i can set them up from here... its a commercial renderfarm ....the problem is the affect materials :1.8 which i work with ...since it wont be on , the renders will look dark or pale?
Any commercial farm that is set up half decent should have 'Load Enabled State with Max Files' set in the preferences. This should keep you from having any problems regarding the gamma.
I would email them, and ask if they are set up like this. I would also ask for them to let you send a test file with a 10 frame animation just to make sure your system, and there system play nicely. This way you know your money will be well spent.
okay i am changing the materials with the color correct plugin and the gamma correction in color mapping
if you are using the third party color correct plugin, then you are going to run into greater problems than just a wrong gamma. I believe this plugin would need to be loaded on the renderfarm side. You would need to inquire with the rendering service to see if they have that plugin as part of their setup.
