jpeg and c4d
tom10
Does anyone know if you can import a jpeg into cinema 4d and have if fade into the scene within an animation? Basically, I want a jpeg image to fade in gradually whilst I have a moving object in front which I have modelled in cinema 4d. I understand the basic fundamentals of animation and how to make the object move etc, ive just not sure if you can merge a jpeg image into the background and have it gradually fade through. If anyone can provide any information I would greatly appreciate it.
Kind regards
Tom
hi,
i am sure that other users will come up with many solutions
(depending on what you are after for), but a simple way to do it is to animate the brightness values in case you have load it in the color and/or luminance-transparent channel.
hth,
george
You can stick the .jpeg as a texture on a plane, position it where you want then add a DISPLAY tag. You then animate the percentage of visibility with keyframes within the tag. You can see where I have keyframed it below and the icon for the display tag. To keyframe the visibility you can either hold shift and left click on the little circle or right click, animation, add keyframe.
So as an example you keyframe it at 0% on frame 1 and 100% on frame 500 for it to fade from nothing to full over 500 frames.
Edited by BillyElNino
William, that sounds the simplest. I remember trying that about 4 yrs ago and it was impossible. Display was either on or off with no transition. Maybe that has been corrected in newer versions.
Tom, an alpha channel has nothing to do with which software you are using. EVERY 3D app should be able to render with an alpha (transparent) background. Are you new to 3D in general?
Hey thanks for your reply guys. yes i am new to 3d.
Will, i tried your advice. do i need to carry out the render to see the results because at the moment when i press play the jpeg image goes from 0 to 100% instantly, and not gradually. maybe i am doing this wrong or perhaps i just need to carry out the renderd animation to see the outcome.
secondly. do you know if this is possible to fade the image from left to right?
thanks for all your help. i really do appreciate you taking the time to provide me with advice. i am new to animation and to cinemA 4d so thank you!
cheers all
tom
What you are trying to do with the left to right fade does not need the display tag function, what I would do is load your texture into the color channel then activate the alpha channel. In the alpha channel select Gradient in the texture box, if you then click where it now says gradient you can then keyframe the black and white of the Gradient in the alpha to animate how much of the image is faded out and when. The Alpha will work by overlaying a black and white image (or percentage of black and white like the gradient) over your image and the black (or the white) parts are then removed from the image by the program.
It might take some experimentation but with a few goes you should be able to tackle it. Alpha channels are a key part of architectural visualisation and you should investigate them further, for animations and still images they are very useful.
I apologize Tom. After re-reading my last reply, I realized it may have sounded condescending. That was not my intent at all. I was simply trying to gauge your knowledge and experience so that future replies would be understandable.
What William, has been showing you is that almost any feature of Cinema can be key-framed and his solution to a horizontal fade is quite slick. Its certainly a workable way to solve your problem.
However, if you have post-production tools like After Effects, Final Cut, or even Premier, I highly suggest you do this in post. That way you can experiment more freely with the fades and backgrounds without re-rendering your animation.
I agree, you'll get greater flexibility in a post application and this is the first way I would approach it.
I was working on the assumption that Cinema 4D was the only app. available...
William, thanks once again for your reply. i will give that ago, and i am sure it will be spot on. cheers mate. will let you know how i get on. you seem to be abit of a wiz with c4d!
thanks again
cheers
tom
