Animation whith moving objects
Mike.
Hi,
that is the first time i have to make an animation whith moving objects.
To avoid flickering on fly through animations, i used to use the method consisting of calculating and saving light cahche then irradiance map for the whole animation, and then render it from the calculated LC and IR.
Now i have no idea about how to avoid flickering in real animations, i mean whith moving objects.
Would anyone have a link, or could explain me the main ideas behind this ?
Thank you very much.
Edited by Mike.
Thanks Guys :)
I'll look through each of the methods you mentionned to see what fits the most whith my needs.
i also posted on another forum and received this answer.
One way to do it would be to use the "Animation (prepass)" and "Animation (rendering)" modes of the irradiance map; there is some more info on this in the V-Ray help index here:
http://www.spot3d.com/vray/help/150...edimap.htm#mode
Best regards,
Vlado
