Tim Saunders Posted August 25, 2008 Share Posted August 25, 2008 So our IT guy finally upgraded my MAX, but he seemed to miss where I specified to install MAX 2009 Design! And he has the regular Max 2009 installed. Of coarse it will be several days before he can get the problem resolved. In the mean time, I'm wondering if I should go ahead and work in Max? Are both Max and Max design compatible with each other? Will I have any problems scenes I create in Max with Max design? Link to comment Share on other sites More sharing options...
Devin Johnston Posted August 25, 2008 Share Posted August 25, 2008 From what I understand they are virtually identical with a few small exceptions. Link to comment Share on other sites More sharing options...
SandmanNinja Posted August 25, 2008 Share Posted August 25, 2008 I swear I read in Autodesk's doco (somewhere!) that a scene created in one would load/compile in the other. Link to comment Share on other sites More sharing options...
BrianKitts Posted August 25, 2008 Share Posted August 25, 2008 I would sure hope they are compatible. If 2009 is basically just the host for a SDK so that developers can create extensions to 2009 design, then it sure better be able to interoperable between the two applications otherwise they would have had to put out a version for 2009 Design with an SDK. Link to comment Share on other sites More sharing options...
Trevor Tizard Posted August 26, 2008 Share Posted August 26, 2008 You'll be fine...........they are the same product with a couple of minor extra features. Link to comment Share on other sites More sharing options...
Tim Saunders Posted August 26, 2008 Author Share Posted August 26, 2008 I figured so. Just wanted to double check. Thanks. Link to comment Share on other sites More sharing options...
