Dave Buckley Posted August 26, 2008 Share Posted August 26, 2008 i have a building shell in autocad architecture, inside this shell i wish to place several machines which are xref'd from another dwg. my problem is that when it comes to rendering, the shell will render on its own with no problem. if i then open the other dwg and render numerous machines it renders fine the problem is when i xref the machines into the building shell dwg and then try to render?? i get the good old famous FATAL ERROR message, and i can't figure out why. shell renders, machines render, shell and xref machines don't render Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted August 26, 2008 Share Posted August 26, 2008 A logical first step is to check your RAM usage the amount of RAM you have available. Link to comment Share on other sites More sharing options...
